FTS+Antilag question
- VTEC Inside
Hello I have a question to the FTS users. I am using FTS+Antilag and sometimes when I shift and keep WOT when I let my foot off the clutch pedal it looks like the car is off until I let off the gas pedal and push it again and then it goes. I hope you understand what I mean because my English is not so good
Any ideas what could it be?
- VTEC Inside
- VTEC Inside
- VTEC Inside
I tried to make it happen today but I couldn't so I came to conclusion that the problem is in the clutch switch. I figured out that sometimes the pedal doesn't come all the way up and when I let it off the car stays at FTS limiter. I guess the problem is that I have too much pedal free play but I will try to fix. I am trying to find another switch which I will be able to tune where to activate. I hope everything said makes sence to you
BTW here is the log from today. It's just some driving with FTS+Antilag
I'am driving at around 12psi because my 550cc's go more than 90% at 14psi. I will be swaping them with 680cc soon and hopefuly after that will finally go to dyno tune it and will be able to make 20psi
- Crusin 14.elf
- (1.25 MiB) Downloaded 377 times
- VTEC Inside
It hapened again yesterday and I'm pretty sure the problem is not the clutch switch. Here is what hapens: When I shift with full throtle and let of the clutch nothing hapens and I have to let of the gas pedal and push it again and then the car goes. Too bad I don't have it logged
Do anybody nave any idea what could be reason for this?
