Help demon not licensed?
buntinboy9
Hey my computer crashed a while ago and now I am having problems. I can hook up to my demon but every time I do it says that the license number that I have is not validated through eCtune... and dumbass me accidently reset my map on the demon so the car is INOP and its my only mode of transportation... I NEED HELP. It just keeps saying that the license isnt true. I bought the program through xenocron if that helps and still have my original serial number... please help! kinda frantic right now!
1994 Honda Accord w/ t25 set up @ 6psi
buntinboy9
Easiest is to dig through your old emails for your serial code given to you to enter in ectune; for future u should have it written down somewhere... Because with te deamon there is no license.XML to use
It's alot easier than having to go through the re-register process for an ostrich.
buntinboy9
but see thats the problem I do have it wrote down (printed recite from xenocron with it on there) and when I enter it it says that it is not registered with the vendor ectune, like I don't have a license with it. Is there a step that I forgot to enter into ectune that I need to have a piece of information to run it? I did have to re-install windows on my computer but I dont see how thats hurting me right now.
bigdaddyvtec
Have fun with that. We had to FIGHT to get DRqpquts SHIT TO WORK, BACK AND FORTH TO cALVIN FOR OVER A WEEK, RUNNING DEBUG CODE AND ALL KINDS OF SHIT TO FIGURE IT OUT... i HAVE THE PROCESS OUTLINED, BUT ITS ON HIS MACHINE... \ TOTAL PITA GOOD LUCK
750WHP 575 TQ Leed/eCtuned H22 CD5 Trick SLUT GFI: HOLLA!!! We build FAST
buntinboy9
Ok I will try this out and bigdaddy... I hope this isnt the caseJaredKaragen wrote:In the emulator menu, choose emulator/ostrich info. Set ectune as the vendor. It should work after. If your serial is all 'f' s then you need new licensing, but this should not be the case.
buntinboy9
buntinboy9
talked to Chris Harris and he was able to help me correct it. For future reference to the topic make sure you download eCtune from the person or store that you bought it from. I downloaded the eCtune from the website and not from the one Chris gave me (bought through xenocron) This was my problem and thanks Calvin for helping me out as well!!!
