AC IACV adjusts IACV regular..but not reverse
combz
confusing title.. I do not have AC in my car...and its disabled in my cal anyways. i used to be able to adjust regular IACV duty, and it would change my idle. Now that has no effect. However if i adjust IACV duty (AC) it changes my idle speed ...wtf? also in my data pane...the IACV dity does not match or even get close to the IACV duty i select in IACV settings..is this normal? can anyone else test? I just started a brand new cal tonight with r15
yeah...well i never had to either...i was playing with the normal one with no changes.. so i decided maybe there could be a glitch..and went to the ac slider right below..and sure enough idle was changing real time with slider. i dont know if its still doing it i have not played with it for a few days... but also the IACV duty doesnt read the same as IACV in the data pane.
