Error code 30
keiichi
Error code 30
hello, I have a error code 30 (automatic transmission A signal) I'm searching here a solution to delete this error code, but I don't find anything I have a P06-A00 ECU with a B16A JDM, the ECU is chip by xenocron and for a manual transmission Auto tranny is disable on ectune, but I have always this error. I have verified that the conversion is all right (resitor and transistor) Have you got a solution to delete this error code
Stragnge you get the code, I use an auto ecu to tune manual cars, I just start with a base auto or manual rom. And it hasn't failed me. If you are sure you enabled the 'disable auto tranny' in ectune, start with a base ecu type of p28 usdm manual.... If you keep seeing the code verify an instant cel if you pull the emulator from the socket while it's running (this is safe), or unplugging j1.
yes i have checked my wiring and it's ok The auto tranny is disable I don't know if the ecu was for a automatical transmission because it's a xenoncron ecu and when I received this P06 it was already chip for a manual I will try top start with a stock p28 base map for information it's this ecu http://www.xenocron.com/chipped-obd1-vt ... p-129.html
