Gpo1 issue
koupanos
Gpo1 issue
Hi i have a problem setting my gpo1, i have put an electo-hydrolic pump for power steering and i want to control the pump from the ecu , i want it to work only for certain rpms an km/h,when i set the limits the ecu send only a blink at the test led and the the gpo1 is off . For example i have set it to work min 800rpm and max 3000rpm with 0km/h and 0tps its only send a command when the rpm passes 800 and then stops. can you help me pls
Civic turbo
