Loading datalog crash
I opened excatly 40 log files.. All with connect and reconnect like on the dyno.  I did remove one bug..  If you are loading a log file an try to load an other while the first is not loaded yet cause a race-issue.  That is fix.     I never got it to crashes but i had the infitife loop that caused u to presses ok and it keeps popping up.    I never saw the red X.    I'll try to debug more and play more...    All the time the graph window was open..    I'll repeat the xenocron steps...
The loading while the first is not loaded, I think I may have encountered that one, but the application normally freezes up untill the log is loaded, so I was never able to do that.... But I'm glad you got the infinate loop. That one was annoying =) And the Red X, sometimes it was with the graph open, and sometimes it was when you open the graph. Curious; how hard would it be to have the graph update life as you are taking readings? Instead of having it only display a log? Do you think it would eat up too much processing/memory power?calvin wrote:If you are loading a log file an try to load an other while the first is not loaded yet cause a race-issue. That is fix. I never got it to crashes but i had the infitife loop that caused u to presses ok and it keeps popping up. I never saw the red X. All the time the graph window was open..
				blundar
I also seem to be able to make a crash pretty consistently with:    start dataloging  start recording  stop recording  graph    I have to save the datalog, stop datalogging and then reopen it to be able to get graphs consistently without crashes.
									eCtune Team  eCtune Authorized Tuner  Location: Cincinnati, Ohio, USA  \"That motor's hit!\" - me
But after recording it doesn't load the dlf file so how does graph crashes... Dave can u go in more detail?blundar wrote:I also seem to be able to make a crash pretty consistently with: start dataloging start recording stop recording graph I have to save the datalog, stop datalogging and then reopen it to be able to get graphs consistently without crashes.
