won't close
won't close
well i was able to get a base map going and the car idles but when i goto close the program after i'm done. it won't close. am i missing something? was this covered before? is there a fix? i can't even end the task with the task manager
did you use direct innovate wideband. Did you had Emulator or datalogging errors? task manager always close everything by end process on the second tab.
something went wrong i can't tell you what. I would say make sure your .net framework is updated and you are running version 0.0.2.1 r8. Try it again try to find what is causing it so i can fix if it's a problem. But i don't have that problem.
