Code 20, ELD with ectune?
Garrett wrote:
combz wrote:garrett what code was ectune showing? in the error codes?
20
This normal for P30 and p72
combz
Post by combz »
calvin wrote:
combz wrote:i am not blaming ectune, i am trying to figure out whats going on..logically. VE correction is disabled, and closed loop is off, and so is o2 heater. when the code is thrown the car starts to idle different. The wierd thing is...ectune says in the sensors window that the MIL is "ON", however it does not turn on in the dash.... code 20 shows up in ectune error codes window, but not in the dash...and yes the check engine light works. I'm at a loss for ideas, im just trying to provide as much info as i can to someone who might be able to help. I tired my friends hondata unit in my car the other night, i didnt get an ELD code but the eld voltage was still 4.8 ish... so hondata might handle that a bit different. Another wierd thing, when we tried my ectuneunit in his car, to get it to idle , we had to add double the fuel in the raw fuel values...he has 750 cc RC injectors as well...except his are low impedence and he runs a resistor box. i dont know what the deal is lol.
ELD doesn't turn on MIL.
why does ectune say MIL is on then and showing code 20 in the error codes box? i am confused... so its normal to have this ectune MIL for code 20 on a p72 map? or is the p72 ECU itself?
what eCtune MIl... your DASH mil won't light up from code 20. In ectune you should see it
non-vtec
Post by non-vtec »
mine does the same thing. i just dissabled ELD. just like you said it will idle funny when the ELD code is present. once ELD is dissabled it idles a little better. i dont care for the ELD as long as the engine runs/performs properly. i would not worry much about it.
