I tried again same thing is happening except now the cel blinks 3 times. here's what it says This is on manual DTL: baud: 38400 DTL: The operation has timed out. DTL: Retry #:1 DTL: The operation has timed out. DTL: Retry #:2 DTL: The operation has timed out. DTL: Retry #:3 DTL: The operation has timed out. DTL: Retry #:4 DTL: The operation has timed out. DTL: Retry #:5 This is on auto DTL: Ecu detection started DTL: baud: 38400 DTL: Cached port failed with Object reference not set to an instance of an object. DTL: Open port : 2 DTL: Open port : 2 DTL: The operation has timed out. DTL: Retry #:1 DTL: The operation has timed out. DTL: Retry #:2 DTL: The operation has timed out. DTL: Retry #:3 DTL: The operation has timed out. DTL: Retry #:4 DTL: The operation has timed out. DTL: Retry #:5 DTL: Port 2 is open and check ECU-ISR replied=False DTL: Open port : 5 DTL: Open port : 5 DTL: Open port : 6 DTL: Open port : 6 DTL: Open port : 9 DTL: Open port : 9 DTL: Port Scan Failed at port 30calvin wrote:try to run manual connect and post comm trace again. select proper port
datalog problem
try it both ways http://forum.ectune.com/viewtopic.php?t=1626
