NA tunes, watch out!
So if I am understanding this right, then the ROM was trying to read from collumns that you did not add which were not tuned, correct? Also, I guess this is going to be part of some of the new updates, ie. the program will know when it is trying to read past the map and would throw a fit or atleast throw a code so you would know. I thought that the program had some sort of safety net against this so now I am a bit paranoid. Another note: should the PA baro option help alleviate this issue? Has this hardware been disabled in the code? I cant remember last time I checked. Thanks, Matt
Indeed....So if I am understanding this right, then the ROM was trying to read from collumns that you did not add which were not tuned, correct?
I dont know. I have no baro in my ecu. I thought Calvin did not found the complete baro correction in the software yet.Another note: should the PA baro option help alleviate this issue? Has this hardware been disabled in the code? I cant remember last time I checked.
