Update to latest eCtune Ver(0.0.2.3 r16) 07/31/10
Code: Select all
v 0.0.2.0 r5  ***Note&#58; Comments/Options/Features with X or finished or coded  -Rom 0.0.48 Vtec reset bug    -Rom 0.0.49   *FTL     *memory set with button&#40;chris/JD&#41;  - X    *Rev/Burnout with button&#40;chris/JD&#41;     -Ebc    *EBC hz    *Closeloop based on deltaMap    - Duty lookup table auto setup&#40;xenocron&#41;    - Lo/Hi target psi&#40;xenocron&#41;    - Fixed duty&#40;xenocron&#41;      - Alternative IAB output - X   - Remove fuel correction based on ELD when  closeloop disable stock method - X   - Remove bug o2 heater output - X   - Target o2 map instead VE    - Soft rev limit&#40;burgermass/hackish&#41;   -  Lean protection&#40;1/2&#41;    - Disable during fuel cut    - Timer    - AFR based on WB   - Overheat protecting    - Boost cut enable or Adjustable Rev limit - X    - License.xml missing error - X  - Tested verify rom working - X  - Alternate vtec output enable checkbox disable if non vtec ecu - X  - Alternate iab output enable checkbox disable if iab disabled - X  - h22 290cc/330cc maps old injector size - X  - Open file cancel button&#40;borat&#41; - X  - Crashes on big log load and graph button clicked&#40;allan&#41; - X  - PLM wideband settings&#40;redshade5&#41; - X  - Bug MRU open file - X  - Fixed check for software exp date - X  - Change interpolate row/column to X-axis/Y-axis - X  - Remove dead code old license file - X
Code: Select all
v 0.0.2.0 r6  ***Note&#58; Comments/Options/Features with X or finished or coded  - Emulator debug window&#40;mbter&#41; - X  - Emulator error msg if the baud is not 921600 or 115200 - X  - Bug emulator timing&#40;mbter&#41; - X  - Bugs sensor setting&#40;JaredKaragen&#41; - X  - Bug auto-scan datalogging&#40;various users&#41; - X  - Bug clear wideband conversation setting&#40;JaredKaragen&#41; - X  - JAW wideband added to settings&#40;JaredKaragen&#41; - X
an bug on the force update was brought to my attention. User you will have to extract the attached file in the root of ectune folder. Otherwise forceupdate might not work. Or you have to do a clean install with the eCtune Setup.
Webupdate.Update.rar
Update Webupdate 4-dec-2007
(126.83 KiB) Downloaded 2512 times
Update 0.0.2.0 r7
Code: Select all
 v 0.0.2.1  ***Note&#58; eCtune now Uses .Net Framework 3.5  ***Note&#58; Comments/Options/Features with X or finished or coded  -Rom 0.0.48   - Bug fix high cam only feature.   - bug with manual boost controller&#40;burgermass&#41;   - Fan control bug&#40;maddog20&#41;  -Rom 0.0.49/NOT USED   - Bug fix high cam only feature.   - bug with manual boost controller&#40;burgermass&#41;   - Fan control bug&#40;maddog20&#41;  - Rom 0.0.51   - Remove bug o2 heater output - X   - Alternative IAB output - X   - Fan control bug&#40;maddog20&#41; - X   - bug with manual boost controller&#40;burgermass&#41; - X   - Bug fix high cam only feature - X   - Disable stock routine if input being used for something - X   - Ebc    - EBC hz - X    - Fixed EBC target multiplier range - X    - Dial knob input&#40;eld, egr, b6&#41; adjust target psi - X    - Closeloop based on deltaMap - X    - Duty lookup table&#40;psi&#41; auto setup&#40;xenocron&#41;     Changing map sensor - X     Creating Base Map - X     right click dutytable - X&#40;with wg act input&#41;-X    - Lo/Hi target psi&#40;xenocron&#41; without table -> needed? no      -  Lean protection&#40;1/2&#41; - X    - Disable during fuel cut - X    - Timer- X    - AFR based on WB - X   - Redo FTL, FTS, Boostcut, Antilag, Overheatprotection routine aim faster reaction - X    Boostcut - X    Overheat - X    Lean protect - X    FTS - X    FTL -no need    Anti-lag - no need   - Overheat cut rpm adjustable - X   - Bug fts clutch input not showing with datalogging - X   - Disable routine if input use else - X    - Rom 0.0.52   - Remove fuel correction based on ELD when  closeloop disable stock method - X   - Closeloop checkbox disable on MIL/Lean - X   - Closeloop input selector - X   - Datalogging deltaRPM - X   - New boostcut code - X    - Demon old get rom failed - X  - Bug with invert datalogging input&#40;JaredKaragen&#41; - X  - Bug with eCtune Datalogger version download&#40;RoadXY,Maddog20&#41; - X  - Bug with eCtune Datalogger version opening with a saved map&#40;Maddog20&#41;-X  - Fan control temp input&#40;temperature input validation fix&#41; - X  - Ostrich validation&#40;fixed ?&#41;-X  - Fuelcut on/off not showing in graphs&#40;maddog20&#41; - X  - Remove offset when using wideband closeloop&#40;gaskleppie&#41;  - Ostrich serial don't remove on vendor switch&#40;moates&#41; - X  - add license info to register dialog&#40;nate&#41; - X  - If ectune ISR was selected and switch to ostrichECT, use datalog port was still checked - X  - Bug checkbox upload on emulator connection - X  - Innovate Direct access added - X  - Map tracer get stuck&#40;burgermass&#41; - X  - Select all&#40;ctrl-A&#41; on grid did not reflect on 2d/3dgraph&#40;burgermass&#41; - X  - High cam only bug&#40;xenocron&#41; -X  - Bug with afr display due to new AFR variable in datalog frame&#40;frank&#41; - X  - New methode of storing AFR in the log file. AFR is the currently selected input&#40;o2, eld, egr, b6, direct&#41;   When opening a log it doesn't matter which input is selected. - X  - Check duty cylce validation input&#40;boost controller settings&#41; &#40;JaredKaragen&#41; - X  - Test manual/staged boost controller&#40;burgermass&#41;  - X  - Remove emulator ISR warning.. auto put in ostrich v1-2&#40;xenocron&#41; - X  - D11 EGR wideband typo&#40;orthello&#41; - X  - Serial wideband did not remember port on startup&#40;burgermass&#41; - X  - Live graphs serial wideband&#40;new o2 log variable&#41;&#40;frank/xenocron&#41; - X  - Tps retard gear correction valdaiton and naming&#40;xenocron&#41;- X  - bug ebc compensation calculation&#40;cj&#41; - X  - fuelcut in datalogging graph showed as -1 and 1 it is now 0 and 1-X  - FTS clutch input doesn't show - X  - 2grahps time line doesn't show in datalgging graph - X  - Disable stock input switch if input in use somewhere else&#40;cj&#41; - X  - Bug table trace duty compensation - X  - 2d table button disable - X  - EBC duty psi auto setup with map sensor change&#40;xenocron&#41;- X
Code: Select all
  v 0.0.2.1  - Check all parameters tab usage&#40;xenocron&#41; - X  - Check all setting tab usage - X  - AFR byte in log file&#40;different input of wideband&#41;&#40;nate&#41; - X  - Burn1 verified failed color red&#40;allan&#41; - X  - Fuel pressure/offset basemap creator&#40;burgermass&#41; - X  - Solenoid config check min and max&#40;xenocron error&#41; - X  - Vtec tps settings check min and max - X  - Rev limits settings check set>reset - X  - IAB setting check iab set>reset - X  - TPS sensor settings check min/max - X  - AC settings desengage/enagage rpm check - X  - Tps retard check min/max vss and min/max rpm - X
Code: Select all
  v 0.0.2.1 r1  ****MAJOR OBJECT CLEAN UP&#40;aim lower memory usage&#41;  -Rom 0.0.53   - Limit fts at current rpm when clutch pressed - X   - Fts anti-lag   - Bugs regarding fts/ftl/igncut - X     --Bug fixes after testing  - fix high/low load vtec settings&#40;xenocron&#41; - X  - Enable boostcut on DTC change label&#40;xenocron&#41; - X  - TPS retard correction -100/100 change&#40;xenocron&#41; - X  - TPS retard base retard value change to negative&#40;*-1&#41; - X  - Detect/Erase burn1&#40;JD&#41; - X  - Popup for ostrich 1 get rom - X  - Check box high cam didn't throw save event&#40;JD&#41; - X  - Test datalogging bugs blundar-Tested by other reported working - X  - Check for eCtuneISR none Dev verison- X  - Live graphs problem with reseizing&#40;plot remains good&#41; - X  - datalogging graphs when enabling 2 graphs time line not drawn - X    ---test report bug fixes  - Duty error table disable/empty when rom has no closeloop&#40;civic_tsi&#41; - X  - Lean protection didn't show in datalogging graphs&#40;z31&#41; - X  - Valid keypress edit mode tables advance/grid&#40;civic_tsi&#41; - X  - Upgrade question if opening a older rom&#40;allan&#41; - X  - Problem with afr byte in datalogg on reply - X  - ROm comments 0x8000&#40;civic_tsi&#41; - X  - Remove/invisable gear vs rpm limit&#40;civic_tsi&#41; - X  - New calibration doesn't check rom modified&#40;civic_tsi&#41; - X  - RPM scalar start column not working&#40;non-vtec&#41; - X  - Upload Rom on emulator connection doesn't stay checked&#40;non-vtec&#41; Cannot duplicate - X  - Insert/Delete columns - X    - Insert column with map <24 columns - X    - Insert column with map =24 columns - X    - Delete column - X    - Insert row - X    - Delete Row - x    -confirmation question insert - X    -confirmation question delete - x  - Selectable Input closeloop UI - X  - Tuner option adjustable MIL flahs for ID -X   - License dependend flahses&#40; free =5, Pro=4, diy=3&#41; - X  - Tuner able to copy protect maps - X  - Slider for ebc closeloop sensiticity - X  - check boost setting hot/cold increase F&#40;rschoener&#41; - calculation math.round - X  - Message box wideband settings when entering a afr value in rom&#40;closeloop/lean protection&#41;- X  - lean protect enabled on open cal - X  - Snapshot list bug&#40;civic_tsi&#41; - X   New type of snapshots; snapshot use the current directory. on exist everything is save on next open of rom/cal   snapshot list and snapshots are retrived  - Add messagebox when license is about to expire&#40;John vega&#41; - X  - TPS scalar setup - X
Code: Select all
  v 0.0.2.1 r2  - rom 0.0.54   -fix secondary ign map low cam - X   - GPO fuel add/substract fuel now - X   - GPO activate high cam map removed - X    -ALt vts output good for vtec activation - X   - FTS anti-lag - X   - Remove anti-lag option apply to final ign&#40;now always applied to fnl ign&#41; - X    - Secondary maps low cam ign not working&#40;mbter&#41; - X  - Snapshot manager should check if the file is already saved&#40;not emulator/new rom&#41; - X  - detect installed .net framework version - X  - hot/cold thershold rev limit settings not saving - cannot duplicate - X  - register ocx on startup if not registered - X  - Settings tab multiline - X  - Direct widebad has to opensettings first - X  - Bug check fnl ignition anti-lag not working - X  - Remove apply to final ign anti-lag - X  - Init new rom values on opening older calibration&#40;lean proctec enable on old cal open&#41; - X  - Copy paste parameter window adv tables&#40;JK&#41; - X    - Test GPO fuel ign correction&#40;mbter&#41; *Running - X  - Test anti-lag static ign value *Running - X  - Test closeloop *Running - X  - ect fuel test *running - X  - ANTI-lag ftl *running - X  - Anti-lag FTS *running - X  - Msg expire&#40;allan&#41; - X  - Interpolate when insert row&#40;allan&#41; -X  - Hondat/omnipower map sensor&#40;frank&#41; - X
Code: Select all
  v 0.0.2.1 r3 t0  - DOn't ask rom upgrade on creating basemap&#40;tuner version&#41; - X  - Datalogging graphs bug&#40;zex_cool&#41; - X  - Lean protection valiation&#40;JaredKaragen&#41; - X  - Smoothing bug&#40;jaredKargen&#41;-cant reproduce - X  - Lean protection bug&#40;sohcd16y8&#41;-user error - X   - bench tested and post log/cal -X  - Duty look UI validation bug&#40;jaredkargen&#41; - X  - Validation error icon for adv table/parameters - X  - VE correction disabled on all new created roms - X    v 0.0.2.1 r3 t1  - Ostrich registration moved to new server - X  - Auto check update everytime&#40;user cannot disable&#41; - X  - Key off key on datalogging tested on usb&#40;working&#41; - X  - height of advance table in windows xp/vista theme - X  - Ostrich 10.19 support check&#40;dave&#41;&#40;encrypted verify failes&#41;-X  - OStrich 10.20 works perfect - X  - duty look validation error&#40;jaredkargen&#41; - X  - Ostrich info showed if ostrich_1_2 is selected - X  - bug regional offset wideband settings&#40;gaskleppie&#41; - X  - check all textbox leave/validation&#40;jaredkargen&#41; -X    v 0.0.2.1 r4 t0  - ostrich unpair/licensed - X  - Lic exp msg only once&#40;civic_tsi,adam hopkins&#41; -X  - Loading log&#40;nate&#41;&#40;msg status bar/cursor&#41; - X  - Crash minimize graph window&#40;jk&#41; - X  - Disabled IAT trim fuel correction&#40;needs redoing&#41; - X
i would say: holly sh*t this is an update see the amount of features/fixes.... I didnt even know till now. Didn't fit in one post :oops:
Code: Select all
v 0.0.2.1 r6  rom 0.0.55   -FTS anti-lag bug - X  - single cell stuck&#40;hackish&#41;/received log/cal from and debugged it - X  - Replace icons&#40;nate&#41;-X  - Ctrl-J to right click&#40;label&#41;&#40;madmax&#41;-X  - Add ctrl-j to context menu&#40;madmax&#41; -X  - add ctrl-j to toolbar&#40;madmax&#41; - X  - VE disable button enabled in Dev/Tuner only - X  - if ve disable disable ve min ect textbox - X  - Re-enabled the cell painting to show interpolation on cell trace with enable/disable - X  - prevent load rom refresh everything 2 times on opening calibration - X  - Copy paste parameter window&#40;JK&#41; - X  - Add G command to main commands quick keys - X  - Overall fuel trim popup - X  - Injector offset popup - X  - Shortcut keys added   -Tps cal/\"Ctrl+T\"    - X   -Overall trim/ \"Ctrl + =\"   - X   -Injector offset/ \"ctrl + -\"  - X   -Ign Sync/ Ctrl + I    - X   -Kill Injectors/\"Ctrl+K\"   - X   -Boost table Setup/\"Ctrl+B\"   - X   -Clear error&#40;dtc&#41; code/\"ctrl+u\"  - X  - Webupdate should delete old bins if delete from server - X  - Show peak boost value only&#40;just max&#41;&#40;nate&#41; - X  - Decimal units points for analog inputs&#40;allan&#41; - X  - parse through log for max values&#40;nate&#41;- X  - ADD ign iat retard default to rom&#40;burgermass&#41; - X    v 0.0.2.1 r7  - Injector duration graph showing wrong - X  - Add config flag for parse log for peak on load - X
Code: Select all
v 0.0.2.1 r8  - Can´t select EBC fixed duty cycle&#40;allan&#41; -X  - Update setup mstsdk.ocx - X  - Update msg if software expire - X
THIS IS AN IMPORTANT UPDATE. THIS HAS A LEVEL 2 BUG FIX
Code: Select all
v 0.0.2.1 r9  rom 0.0.56   -USDM p72 IAB ebc fix - X   -JDM ecu ebc fix - X    - error get serial should check FIRMWARE version &#40;pro&#41; -X  - PRO version no auto scan error msg on ostrich info&#40;pro&#41; - X  - Increased size of settings screen - X  - Overlay bugs&#40;civic4g&#41;   -Clear Selected Cells clear all maps, should clear selected map only- X   -Auto adj clears both hi/lo cam, should clear selected map only-X  - setup do force update auto - X  - last column mbar&#40;timdog&#41;   make column edit adjustable in current map display value - X  - Test ISR without auto-scan more info - X  - adjustable voltage scale battery offset&#40;dave&#41; - X  - Battery scale formula&#40;Level 2&#41; -X  - New/Updated battery tables&#40;Level 2&#41; - X  - after changing battery table update 2d graph - X
Code: Select all
v 0.0.2.1 r11  rom 0.0.58   -SCC routine mod    selectable input -X     -If old is 0x80 set to 0x00&#40;input none&#41;, tps koeo always on    option to fixed ign to ign sync value - X   -Error check tps koeo always enable - X    -Kill injectors - X   -Burnout control&#40;burgermass&#41; - X   -Bug with FTL anti-lag timing&#40;timdogg, burgermass&#41;-X   -Bug with FTS anti-lag timing&#40;timdogg, burgermass&#41;-X   -Anti-lag FTL only enables if rpm > ftl rpm - 500 & tps > threshold&#40;burgermass&#41; - X    -Gear Learn tool - X   Custom gear ratios calculator - X   display raw ration vss/rpm - X   display gear raw data -X  -Conditional recording&#40;auto-save&#41; - X   -Bug popmsg crank trim&#40;xeno&#41; - X  -disable always enable burnout control&#40;civic_tsi&#41; - X  -Rom comment bug&#40;eric&#41; - X  -Rom comment start location&#40;civic_tsi&#41; - X  r11.t1  -B6 wideband input error - X  -Conditional Auto-save enable/disable bug - X  r11.t2  -Peak values clear&#40;boosu t remained old value&#41;&#40;burgermass&#41; - X  -Idle ign correction spelling bug&#40;civic_tsi&#41; - X  -Trial version basemap creator didn't work&#40;amr eng&#41; - X  -Adjustable Load for GPO selection&#40;JaredKaragen&#41; - X  -Battery formula&#40;xenocron/nate/calvin&#41; - X   -Old rom new retune required   -If new injector table selected on old tune, retune required   -Drain fuel tank tool-X  -Load display value always in mbar bug in datalogging log window&#40;civic_tsi&#41; - X  0.0.2.1 r12  -Expection bugs due to VS 2008 bug&#40;thomas&#41; - X  -WB display on status bar&#40;civic_tsi&#41; - X  0.0.2.1 r13  -Bug burnoutcontrol - X  -basemap creator slow fix&#40;sypnotic&#41; - X
Code: Select all
  ----------------------------------------------  v 0.0.2.1 r14  rom 0.0.59   -Offset/overall update - X&#40;LEVEL 2&#41;  - Bug with corrupt settings file - X  ----------------------------------------------  v 0.0.2.1 r15  - rom 0.0.60/Tuner only test version   -Tipin second multiplier for response/amount&#40;nate/cj testing&#41;    no multiplier yet just hardcoded BS    - datalogging column1 mbar update refresh&#40;civic_tsi&#41; - X  - delete row high cam bug&#40;moves low cam map&#41;&#40;Xenocron&#41; - X   - fixes for insert delete row/column, only edits the selected map fuel and ign;not all maps - fixed  - click column header a few times for crash&#40;hackish&#41; - X  - NTP tamper on none datalogger version only - X  - cell trace weight color changed to white - X  - peak boost not clearing&#40;burgermass&#41; - X  - cell trace single lock&#40;greasemonkee&#41; - X   - tested with KOEO bench, lock up of datalogging occourd - FIXED   - Display, graphs focus instead of recreate object - FIXED  - Peak value VSS always showed KMH&#40;yc underground&#41; - X  - Map value for peak value log parse bug - X  - bug edit load scaler in InHG Gauge mode&#40;sohcd16y8&#41; - X  - insert column in InHG Gauge mode messed up fuel map&#40;sohcd16y8&#41;- X
will require retune..
