can more people test?civic4g wrote:Is the routine the same in the version available through force update and the 6.2.2009 update (demon+ostrich update). I ask these because in 6.2.2009 you ask me to test, fuel cut is working but not so good has it was in later versions (0.0.2.3.r0). I'm getitng hiccups when cruising with light throttle.
how to set decel fuel cut?
just updated yesterday,you guys are crazy, go drive around in a parking lot and adjust in 50 mlb incraments. no other tuner has problems! im telling you if you set it right it works just fine.don't for get to disable and tune in and out
I have my cut set at 260 mbar. At 2200 rpms on normal decel, it starts to cut in and out. With the ac on, this starts to happen at 3200 rpms. I am just wondering if I use alphanumeric instead of IM pressure in the load columns, will fuel cut be based off of TPS? My motor dosn't pull a lot of vacuum. Hey calvin: Are you going to be working on that fuel cut load vs rpm table any time soon? Because that would be awesome to have. I am more than happy to test this for you
set your datalogging refresh rate higher check log file you will see that you are above 260mbar try 300mbardbsharp wrote:I have my cut set at 260 mbar. At 2200 rpms on normal decel, it starts to cut in and out. With the ac on, this starts to happen at 3200 rpms. I am just wondering if I use alphanumeric instead of IM pressure in the load columns, will fuel cut be based off of TPS? My motor dosn't pull a lot of vacuum. Hey calvin: Are you going to be working on that fuel cut load vs rpm table any time soon? Because that would be awesome to have. I am more than happy to test this for you
