Wont connect to datalogging on version 0.0.2.0r5
Adam Hopkins
Post by Adam Hopkins »
integralactic wrote:Datalogging with auto scan checked now works for me in 0020r6. Still cant get or verify rom. Dont know if its a bug or my computer.
I also cant verify or get from ostrich.
ostrich 1 or ostrich 2? You removed the vendor ID settings right? Clear vendor ID and use ostrich v1/2 in ectune tuner version
Adam Hopkins
I will try this when I get home, I am in school right now taking my last final (P.S. I called PayPal today, set on hold for 15 minutes, got hung up on, called back and sat on hold again for 20 minutes to find out my credit card was expired on file. Thats what was causing all the problems. Will not happen again for sure.)
ostrich verify works on tuner version ostrich 1_2... I have to debug it futher.. why it's not on single car
Menthos
Post by Menthos »
Menthos wrote:where can i get the update / fix? :?
Adam Hopkins
Calvin clearing the vendor ID and changing my settings fixed all problems. I was unaware that I had to change that setting when I upgraded. Just user error on my part. Once again excellent customer service, fast response, and no bugs. Thanks again! :D
Do u have a single car version or do u run ectune in your ecu?
Menthos
Post by Menthos »
i use the logger version on my computer and i don't know about my ecu... i don't know so much about ecu and fine tunning of it, so i payed "Bindegal" from this forum to install the ecu and fine tune on dyno..
Yes indeed. So, logger version only. And apparantly it worked before the R5 release. As far as I know, Menthos uses an RS232 interface. I´m not sure if it is a direct RS232 cable to the PC - or if some USB conversion is done? /Allan
Menthos
Post by Menthos »
Bindegal wrote:Yes indeed. So, logger version only. And apparantly it worked before the R5 release. As far as I know, Menthos uses an RS232 interface. I´m not sure if it is a direct RS232 cable to the PC - or if some USB conversion is done? /Allan
i use usb conversion... got no serial port on my laptop :) and yes it worked before i updated...
i'll issue a new release soon. Ned to change some minor things
Menthos
Post by Menthos »
ok.. sounds nice...
Menthos
Post by Menthos »
when will the update come? i kind of need it soon... can't you just give me a fix like the one RoadXY has got? sounds like we have/had the same problem...
OneLudeSol
Post by OneLudeSol »
Same problem here with the logger version...
I'll update it later this week
