LOL.. done exactly the same thing at 7.15am CETAlmighty-Si wrote:I just force updated and it went back to 59. I will take it out in the morning and test datalogging on the way to work and report back.
update problem
- Orthello
can you go in to detail about this? Sometimes the recorded values dont display for me either. I guess I dont fully understand the overlay settings completely.Orthello wrote:It takes a while before the first recorded values appear. Force updated eCtune about 1 hour ago and I'm fully capable of creating nice logs, including the log window.
Well, datalogged on the way to work and for some reason the map trace is white and it won't log idle. I have all the gears selected and tps is -13 to 113 so it should log idle but it doesn't for whatever reason. I will look through my settings some more but from what I saw everything is ok. It does however log just fine on the throttle from what I could see. I didn't get a good log because I had to re-install the drivers this morning and was a bit rushed and forgot to set the correct baud rate and latency timer in the com port and realized that when I got to work (which is when I adjusted them and it won't log idle) so now that they are set correct I will get a nice log for the ride home if you need it.
AFR values in the log window are cummulated/averaged over a set amount of samples, to get a more reliable measurement in the log and to partly eliminate interpolation issues. So let's say eCtune averages 20 samples per cel. So when a cell is touched 20 times, finaly an AFR value will appear. It's not axacly what happens, but this is the best explanation I have from the top of my head at this moment. Correct me if I'm wrong/incomplete.
select gear 0(afr overlay) for idle loggingAlmighty-Si wrote:Well, datalogged on the way to work and for some reason the map trace is white and it won't log idle. I have all the gears selected and tps is -13 to 113 so it should log idle but it doesn't for whatever reason. I will look through my settings some more but from what I saw everything is ok. It does however log just fine on the throttle from what I could see. I didn't get a good log because I had to re-install the drivers this morning and was a bit rushed and forgot to set the correct baud rate and latency timer in the com port and realized that when I got to work (which is when I adjusted them and it won't log idle) so now that they are set correct I will get a nice log for the ride home if you need it.
Well just tried to log on the way home and the idle cels again werent working but I gave it a rev and it logged other cels so I closed the lid and went on my way. When I stopped I got an overflow error and then checked my com port settings and the baud rate adjusted itself back to 9600. Well I will go over all my settings now again, going to update drivers and try again tomorrow, will report back then.
Ok well I updated my drivers (02.04.06 from FDTI website) and connection is much better and its actually saving my settings now but trying to log on the way to work got me an overflow error again. Going to try and get it to pop up again on the way home and take a screen shot of it to post up later on. Also my trace is still white but I did get it to log at idle. One of the settings were off don't know how I missed it, sorry !
Well datalogging is still weird...trace is still white and the car actually stalled on me 3 times today. Had the overflow error come up but I adjusted it according to the sticky on the top of this page so we'll see how that works tomorrow. The stalling is a weird issue...something just clicks and stall...but re-fires fine.
Well got the overflow error again. Had it at 90 then 85 then 80 now 70 and it finally stopped giving the message but the trace still jumps to the last column on decelleration. It didn't stall on me today but the datalogger did lock up on me 2 times, the trace is still white after trying an update again and the car revs a little connecting and disconnecting to the datalogger. When it locked up it froze the program to where I had to close it out and open it up again, pull the USB (or it wouldn't recogize the ECU) and click connect again. Never knew how difficult that all was to do while at highway speed
Good thing I goto work at 5am. That's it for now, the car seems to be running fine though without datalogging connected and its weird but I don't get any error messages when things lock up on me. I will log on the way home and see if anything happens again and will report back.
