Posts: 258 http://phpbb3styles.net
Post
by sohcd16y8 » Fri Aug 01, 2008 12:33 am
Your ecu will function fine without that. Im not 100% sure what it is, but I have chipped many ecu's with and without it and they all ran fine.
fireztorm
Posts: 29 Joined: Sat Jul 26, 2008 3:31 pm
Post
by fireztorm » Fri Aug 01, 2008 12:36 am
okok.. but what parts am i missing now? i can see on the link he is using a chip.. i do not need that? i have ribbon cable and ostrich to use with ectune..
Posts: 258 Joined: Sun Dec 16, 2007 12:04 am
Post
by sohcd16y8 » Fri Aug 01, 2008 12:38 am
MM74HC373N-ND 1 The other chip that is reqired 1.0KEBK-ND 1 1K resistor 399-2127-ND 2 .1uF capacitors
fireztorm
Post
by fireztorm » Fri Aug 01, 2008 12:52 am
ok.. thanks
will try that
Posts: 1263 Joined: Tue Apr 03, 2007 11:22 am
Post
by Gaskleppie » Fri Aug 01, 2008 2:10 am
The other black thing is the baro sensor. Euro ecu's dont have that. Just disable it in the software and you will be fine.
Posts: 347 Joined: Mon Apr 16, 2007 10:06 am
Post
by RoadXY » Fri Aug 01, 2008 4:16 am
baro or PA sensor (same).
