viewing psi problems in tables
glove
Post by glove »
I am having extreme difficulty trying to get my row on my 2d fuel tables to display PSI and not MBAR, or both (like crome). when i select psi reading, the boost portion is fine, but the vaccum part is all out of wack, it says 114 mbar is -12 VAC, and try as i might, i cant change it to -26 VAC, im trying to get the same values as my crome tune, but it wont go below -12 VAC, but when i change it back, the mbar's look ok. Is this a bug in ectune? tried searching, found nothing.
The tune will probably differ a bit from the CROME tune; eCtune's ROM handles the values differently; Especially IGN. For one tune I just set the values to the appropreate amount; and whatever it changes to when I confirm the change; I work around that... I honestly was amazed on how much an eCtune basemap felt like a CROME street tune...
