Adding 2.5bar map from stock map and adding column
I tuned a cal for a d16 using the stock map only to 10psi or so... Now we have a 2.5 Motorola and are wanting to turn the boost up I am having problems adding columns, It will let me add one at the end [b21] or right before [b22] using the scaler setup then when I try to add another one to the end again it places it before the first column [1] I also can not change the psi in the columns.. I can change them to 3, 4, 5, 6psi and so on but not say 3.41, 3.86, 10.8.. This is a bad problem because if you accidently highlight one of the boost headers [say 3.41psi] and don't change a thing you get an error [just try to click somewere else] It says 'invalid table entry! please enter mbar value' and I did not change the entry, it was set when I made the basemap... The only way I can figure is that I am going to have to create a new basemap and retune completely. Or do secondary map switching.. Please help.. dk
Hey hows it going bugermass, Thanks for your input I'm glad I'm not completely retarded
dk
When I put in the 2.5, I just bit the bullet and started a new .cal; transposing the already tuned map's corresponding valves, and interpolating the spots not in the old map that were present on the new; I made mine uber big though (resolution) I think 18 col.
