For street tuned cars timing question
I know theres really no other way to tune timing with out a dyno but for those who've tune many cars on the street. I would like to hear your opinion please Ok a B18C1 running a P72 rom and running 1 degree of timing retard per 1lbs of boost. AFR are at 11.5 under boost all the way up to 7.5psi. Is my timing on a pretty safe setting for a street setup?
1 degree per lb, especially if you have ignition adjustments disabled is very safe in eCtune, yes.
Honestly; you will feel and hear it... if you add timing and fuel slowly; just pay attention to the feel and sound... I can clearly hear it and feel it (for hard of hearing I cann hear higher pitches in my bad ear pretty good) and it sounds like bolts bouncing in the motor; and like a hammer hitting a piston. Nice knock detection systems are available, but are rather expensive; but I would rather buy a dynopack
Interesting.. I didn't disable the timing corrections. I always thought you could run a little bit more timing on the b series, like .75 per lb retard. Here are a couple timing figures from my high cam ignition map. 26.75 degrees @ 7.72psi 22.5 @ 11.44psi 17 @ 17.19psi 12.5 @ 22.92psi I honestly don't hear any det and my plugs look great. I stole these timing figures off my crome tune that I paid for and ran around 8k miles on. I'm pretty sure my old tuner would add more timing in the 10th column smooth it out then do a .75 retard or progressive retard. I'd like to know what everyone thinks about this. dk
