after doing a force date my version still says R14? (I tested this version prior to today) Also when I select a Calibration from the Tuned Maps it will ask if I want to update the ROM version to .60. If you click yes it changes the whole calibration. It will also renames the Cal to XXXXXUpgrade.060. I never had this problem before.
I'm having the same issues too. Upgraded to r14, opened my cal file, message pops up saying \"rom version v0.0.59 which is older than the current ectune romversion 0.0.60. Do you want to upgrade?\" I select yes and save it. Re-open the same file and it asks the same question. Same cal file which is upgraded to version 60 shows version 59.
now it's in continous loop of trying to update. It will say updated to R15..then when you open it will keep asking if you want to update again and again. i tried to force update same thing.
Same issue here, if you update the first time, save and then click no to update next time you open it will still work fine until Calvin gets it all straightened out.
TopMountGSR wrote:I tried to update and no update was found.. I tried to force update it and r13 is all I got.
Same heppend to me yesterday. Opened the software and there was no update and when I force updated it said I updated to r13 but when I opened the software again it said r14. I will try this update when I get home.
same things happened to me as of yesterday. i simply ignored it. i didn't want to mess what i was tuning since i was at the mid of doing things and so i choose No. lol now with r15, all good!
