uh oh, mine says .60 as well. Maybe when I tried to upgrade yesterday and that pop up came up that said to switch to .60 and I said yes, saved it that way now? Will it be a problem? I have the original .cal saved anyways but if it's not going to be a problem I will just leave it alone.
Mine is now on r15 update worked How do you tell which rom version you have? Do you ever need to update your rom or does it do it automatic with the program update? Thanks for your alls time dk
i just did the force update. i updated my calibration and now a/f is RICH throughout the entire map. i get 3 blinks after uploading the calibration as well. what's going on? i do see that it is r15.
turbine tuning wrote:i just did the force update. i updated my calibration and now a/f is RICH throughout the entire map. i get 3 blinks after uploading the calibration as well. what's going on? i do see that it is r15.
3 blinks after priming the fuel pump? That is because you use the eCtune pro version. If you didn't had that before, you haven't updated your ecu for a while? The three blinks are there since I don't know when. Quite a while at least.
i'll release update now it should be 59.. not 60... 60 is test version
re-forceupdate and check pls.. but 58->59 does require retune 59->60 won't need retune...
calvin wrote:re-forceupdate and check pls.. but 58->59 does require retune 59->60 won't need retune...
i don't understand what 58-->59 mean, or 59-> 60. so you're saying i'll have to retune the car? can't i just copy and paste the tables into a new calibration? thanks in advance.
58, 59 and 60 are the rom versions that can be chosen when you make a new rom in the tuner version. The pro version automatically takes the last version and which version you have is visible in eCtune. When your curent version is 58 or lower and you want to upgrade to 59, you have to retune your car.
That's odd cause I never retuned the car from 58 and the car is still running flawless. Only thing I have noticed is the car runs a little lean on initial start up which I don't mind being it was WAY rich. Basically fixed itself
oh ok. well i had 60 as of last night, just now i did the new force update and my old calibration is now 59. do i have to retune? i couldn't even idle the car last night after the force update. it was between 10 and 10.5 a/f throughout the map.
