Following the directions in the email I updated the ostrich fine. Installed ectune and tried to run forced update but got this error Tried to open ectune and got this error Uninstalled and reinstalled and now it opens but gives this error If you choose quit it pops up again a couple of times until the windows report error comes up (2nd pic) Anyone see what I'm missing?
Hmmm, that last pic looks identical to the error I started getting last week; just out of the blue one night it started. I assumed it was due to a slow pc with 6 months of tuning usage that was in need for a routine format.
Here's the details but it's a long one: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.Form.set_MdiParentInternal(Form value) at System.Windows.Forms.Form.set_MdiParent(Form value) at žg5cs3Œ›œex0ag‹jk”2.7Œ‡Ž›˜Œšp†™’uÂ�3Œx†5.‘‡Š‡‘Ž•‡†‡(Object , EventArgs ) at žg5cs3Œ›œex0ag‹jk”2.7Œ‡Ž›˜Œšp†™’uÂ�3Œx†5.”‘‘ˆŽ•Â�ŒÂ�() at žg5cs3Œ›œex0ag‹jk”2.7Œ‡Ž›˜Œšp†™’uÂ�3Œx†5.•—œ‡Â�›†Â�•(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.1 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- Interop.MTSSDKLib Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/eCtune/Interop.MTSSDKLib.DLL ---------------------------------------- eCtune.XmlSerializers Assembly Version: 0.0.2.1 Win32 Version: 0.0.2.1 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.XmlSerializers.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging=\"true\" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
stenseltizm wrote:Following the directions in the email I updated the ostrich fine. Installed ectune and tried to run forced update but got this error
That's no error. Taskkill is a program to kill the tast ectune.exe. Apparently ectune.exe was not found -> you didnt have eCtune running when you where updating. Normal message!
uninstall/reinstall do a force update... delete this too.. C:\\Documents and Settings\\<username>\\Local Settings\\Application Data\folder In4Tec_Solutions <username> your current login name
IC that's good to know thanks!
uninstall/reinstall do a force update... delete this too.. C:\\Documents and Settings\\<username>\\Local Settings\\Application Datafolder In4Tec_Solutions <username> your current login name
I uninstalled, deleted that folder, then reinatalled. It seems to open fine now without errors and I resent my registration info so it seems everything is working. Thanks, now I just need my registration validated.
