Ignition Corrections
turbine tuning
I read somewhere I can disable all ignition corrections in boost. Where can I find that feature? I don't know whether I should zero the corrections out on the dyno or not because of high iat's and ect's. I think i'm pulling 3 degrees after ect is 210. Let me know, thanks.
turbine tuning
turbine tuning
- Bindegal
The log should shows which corrections are in effect. If you want help diagnosing this, you need to upload the CAL and logfile. That´s really the only way Calvin or someone else knowledgable can help you. Anything else would result in endless guesswork. /Allan
turbine tuning
i emailed the cal and log to calvin last week, just waiting for a response. here it is. thanks for the help.
- johngsr.cal
- (8.17 KiB) Downloaded 402 times
- jkjk_19072008_2321.elf
- (40.66 KiB) Downloaded 422 times
- jdjdj_19072008_2320.elf
- (71.31 KiB) Downloaded 388 times
- Bindegal
From what I can tell, eCtune does as it is supposed to do. -IAT is very high = IAT ign. corrections active. -ECT is very high = ECT ign. corrections active. -TPS is constant -1%. Thus the ECU thinks you´re idling. Causing idle ign. corrections to be active because the \"idle\" is obviously high as you´re driving along
If TPS was working and IAT=lower and ECT=lower (like not 101 celcius!) your table ign would match final ign perfectly. ECT/IAT etc. trims are always active, also above 1034 mbar even though you check the \"disable ign corrections above\" box. /Allan
turbine tuning
wow thanks a lot for the help. it makes a lot of sense now. do you think i should zero out the corrections for now since it is between 85 and 95 degrees F out here in the summer? my iat's and ect's just won't go down. can i start with lower timing and 0 correction and gradually bring it up while checking plugs? thanks again.
turbine tuning
- Bindegal
As I understand it.... With lower IAT and ECT, your knock threshold should be higher, allowing for more timing. And this is also one point for using an intercooler, by the way.
That´s the whole point of the compensation tables... They are there for a reason. But hey, It´s your engine, tune for whatever makes you feel more safe. In my book, timing should never be left on the bleeding edge anyway. The tables are there to ensure you don´t have to tune manually for every conceivable temperature... makes sense? /Allan
turbine tuning
