Ok, first issue I have is with the launch control input. Im using the service check as input to enable it, it works fine, but Is there a way I can get rid of the solid MIL light when using SCC input????? I thought it was disable once the car was runing. The other issue is with the secondary maps and GPO. using enable second maps with GPO and Ac request B5 input, IT DOES NOT CHANGE to secondary maps. If I go to secondary maps and set it with input B5 and uncheck the enable with GPO, IT DOES WORK. With the GPO option it doesn´t work at all. thanks in advance.
with GPO it works.. make a log file and post the test calibration
