JBird20
Posts: 87 http://phpbb3styles.net
Post
by JBird20 » Fri Jul 25, 2008 7:06 pm
My Gauge is reading low but the data column reads 235F and doesnt move from 235F....car is not running hot
Posts: 1632 Joined: Tue Apr 03, 2007 2:17 pm
Post
by Bugermass » Sat Jul 26, 2008 4:13 am
replace ECT sensor, and or check wiring from ECT sensor to ECU. The guage in the cluster reads from a different single wire sensor .
Bugermass on Sat Jul 26, 2008 4:08 pm, edited 1 time in total.
Posts: 1504 Joined: Fri Nov 23, 2007 4:00 am
Post
by JaredKaragen » Sat Jul 26, 2008 5:20 am
sometimes if there is an air pocket it will read incorrect.. but it sounds like your ECT is buggin out on ya.
JBird20
Posts: 87 Joined: Fri Feb 08, 2008 11:53 am
Post
by JBird20 » Sat Jul 26, 2008 11:59 am
why is the gauge reading correctly but program is reading something different
Post
by Bugermass » Sat Jul 26, 2008 4:08 pm
Bugermass wrote: replace ECT sensor, and or check wiring from ECT sensor to ECU. The guage in the cluster reads from a different single wire sensor .
JBird20
Post
by JBird20 » Sat Jul 26, 2008 4:54 pm
so the ECT sensor sends direct to ECU?...either way...doesnt the dash have to get a single from that sensor right wether it be from some other signal wire...
Posts: 752 Joined: Mon Jun 04, 2007 2:59 pm
Post
by Bindegal » Sat Jul 26, 2008 6:36 pm
Dude.... you really need to read the posts above once again
There are 2 sensors. The cluster has one sensor. And the ECU uses its own sensor. Different sensors. Different wires all the way. /Allan
JBird20
Post
by JBird20 » Sat Jul 26, 2008 9:08 pm
so change sensor on the motor cause thats the one that is not working properly
Posts: 347 Joined: Mon Apr 16, 2007 10:06 am
Post
by RoadXY » Sun Jul 27, 2008 7:08 am
There are 2 on the motor...
JBird20
Post
by JBird20 » Sun Jul 27, 2008 11:41 am
ohhh okY
Post
by Bugermass » Sun Jul 27, 2008 6:42 pm
