will not connect to ecu
fireztorm
Post by fireztorm »
i have ostrich 2.0 and hulog extreme with updated firmware and newest ectune pro i can connect to the ostrich and upload map but it wont communicate to the ecu i do not see the mil light flash 3 times and my datalogging does not work at all. ideas?
then there is a problem between ostrich and ecu. what color is the connect when you are connected to emulator? did you put the ostrich cable properly in the ecu?
fireztorm
Post by fireztorm »
its green. ostrich cable is correcty connected to the ecu
fireztorm
Post by fireztorm »
the red stripe on the ribbon cable is facing towards the middle of the ecu. that should be ok right?
That is correct. Is the ecu a known good one?
fireztorm
Post by fireztorm »
yes the ecu sould be fine the car runs normal. but i cannot communicate with the ecu. ribbon cable is fine too
fireztorm
Post by fireztorm »
any more ideas? :roll:
fireztorm
Post by fireztorm »
on ostrich info the firmware version is 9. is that the newest one?
Im confused here, so the car runs normal but eCtune is not connecting?
fireztorm
Post by fireztorm »
yes the car runs like before. ectune connects to ostrich. but i cannot affect the engine in any way. datalogger cannot connect to ecu either
do you have real-time update enabled?
Garrett
Post by Garrett »
when uploading the first time upload base rom & cal and verify it
fireztorm
Post by fireztorm »
real time update is enabled. it verifies correctly, the emualtor works fine, i can load a map into the emulator and download it to the laptop later. but the mil light should give 3 flashes when i have loaded a basemap & calibration to the emulator right? in this case it do not flash, just the regular flash when i hear the fuel pump.
Garrett
Post by Garrett »
are you sure that de jumper J1 in the ecu is ON? is you remove the ostrich, the car start?
fireztorm
Post by fireztorm »
what is jumper j1? i have removed j12 tough. yes, the car starts without the ostrich.
