Page 1 of 4
will not connect to ecu
Posted: Wed Jul 30, 2008 11:02 am
by fireztorm
i have ostrich 2.0 and hulog extreme with updated firmware and newest ectune pro i can connect to the ostrich and upload map but it wont communicate to the ecu i do not see the mil light flash 3 times and my datalogging does not work at all. ideas?
Posted: Wed Jul 30, 2008 11:12 am
then there is a problem between ostrich and ecu. what color is the connect when you are connected to emulator? did you put the ostrich cable properly in the ecu?
Posted: Wed Jul 30, 2008 11:36 am
by fireztorm
its green. ostrich cable is correcty connected to the ecu
Posted: Wed Jul 30, 2008 11:41 am
by fireztorm
the red stripe on the ribbon cable is facing towards the middle of the ecu. that should be ok right?
Posted: Wed Jul 30, 2008 12:14 pm
by sohcd16y8
That is correct. Is the ecu a known good one?
Posted: Wed Jul 30, 2008 12:22 pm
by fireztorm
yes the ecu sould be fine the car runs normal. but i cannot communicate with the ecu. ribbon cable is fine too
Posted: Wed Jul 30, 2008 1:48 pm
by fireztorm
any more ideas?
Posted: Wed Jul 30, 2008 3:18 pm
by fireztorm
on ostrich info the firmware version is 9. is that the newest one?
Posted: Wed Jul 30, 2008 4:43 pm
by sohcd16y8
Im confused here, so the car runs normal but eCtune is not connecting?
Posted: Wed Jul 30, 2008 5:02 pm
by fireztorm
yes the car runs like before. ectune connects to ostrich. but i cannot affect the engine in any way. datalogger cannot connect to ecu either
Posted: Wed Jul 30, 2008 5:22 pm
by 98vtec
do you have real-time update enabled?
Posted: Wed Jul 30, 2008 9:57 pm
by Garrett
when uploading the first time upload base rom & cal and verify it
Posted: Wed Jul 30, 2008 10:08 pm
by fireztorm
real time update is enabled. it verifies correctly, the emualtor works fine, i can load a map into the emulator and download it to the laptop later. but the mil light should give 3 flashes when i have loaded a basemap & calibration to the emulator right? in this case it do not flash, just the regular flash when i hear the fuel pump.
Posted: Wed Jul 30, 2008 10:14 pm
by Garrett
are you sure that de jumper J1 in the ecu is ON? is you remove the ostrich, the car start?
Posted: Wed Jul 30, 2008 10:20 pm
by fireztorm
what is jumper j1? i have removed j12 tough. yes, the car starts without the ostrich.
