Full Throttle Shift
Full Throttle Shift
When lookin in the Full throttle shift input menu...i see that is has the v-tec pressure switch. Can i use that input by itself(no running wires) to activate it,since at the track it will always be in v-tec and 100% Throttle?
what rom version?.. It will work like this.. CLutch Input is active and TPS is 100% you will hit FTS limit... if you FTL limit is lower then Rev limit you will never hit your rev limit. Make log and post your calibration then we can all see what you are talking about.
