Real-time datalog graphs?
HiProfile
I was wondering if I missed it somewhere... I know about the live plots, but I was really hoping ectune had the ability to display the datalog in the graph box in real-time, rather than after in play-back mode. RPM/AFR/MAP are great for tuning most of the map, but not everything. THe main reason I would like this is to see what corrections are out of whack...
BTW I noticed you can create a really nasty problem if you \"remove\" the last graph template (IE hit remove too much in anger
). Basicly it crashes, then each time after you attempt to bring up a graph template, it crashes (can't find one?). I had to re-install ectune, which sucks because up till this last update, I've always backed it up.
I didn't think I was that lucky.
But we wouldn't need every type of data, nor would we need ever bit it reads. Even 10Hz would be reasonable. I guess AFR/RPM/MAP is okay, but I'd kinda like to see them mapped with thin lines/white background like the datalog reviewer. Only time will tell, especially seeing as how we [are required to] get an update monthly.
i'll add some more live selectable sensor maybe not in the next release but i'll add them... so you can select a total of 3 or4 live plots... time vs afr, load, egt for example
