Serious Error
utkuselamoglu
Serious Error
Post by utkuselamoglu »
Hi, I am getting this error all the time. Ectune runs at the first time normally than, i hit the new button and the basemap creator screen appears. I am follwoing the steps and than hit the finish button than I get this error. Also tried to open my old calibrations again the same... Image ------------------------------------------------------------------ The details.... of the exception.... See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at e0’vxqr3›�›eig0iž�.’1’ud‹q‰ejpˆ�sx0‘Š.™›’‡‡•��˜�() at e0’vxqr3›�›eig0iž�.’1’ud‹q‰ejpˆ�sx0‘Š.OnPaint(PaintEventArgs ) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.UserControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assem
utku selamoglu
utkuselamoglu
i think it couldn't draw the paint image as an graph. ImageImage
utku selamoglu
elevation
Post by elevation »
Try running foce update, or redownloading ectune.
Did you install FRAME NET 2 to 3.5 ?
utkuselamoglu
David974 wrote:Did you install FRAME NET 2 to 3.5 ?
yes all of them already installed...
utku selamoglu
utkuselamoglu
elevation wrote:Try running foce update, or redownloading ectune.
I did 5 times...:) redownloaded and reinstalled always the same issue occurs...
utku selamoglu
it's very pc related. send me an email calvin (AT) ectune (dot) com i'll send you a test version so i can debug. something does look good with your theme.. post your windows theme, windows version, lang selected please
utkuselamoglu
calvin wrote:it's very pc related. send me an email calvin (AT) ectune (dot) com i'll send you a test version so i can debug. something does look good with your theme.. post your windows theme, windows version, lang selected please
Right now it is not possible for you to debug my setup because I have already formatted the machine... Right now there is no problem but I can give you some machine configuration information about my computer setup before it is formatted. ---------------------------------------------- -The language which I use is English for the windows and the regional setting is Turkish. -The theme were 'windows xp style' and color sheme = 'Olive Green' -Windows version is xp english professional, service pack 2 installed. Note: Before I got this exception I have changed my theme to 'Olive Green' and in the 'Display Properties' go to -> 'Settings' tab select->'Advanced' in the opened window go to 'General' tab and set the 'DPI Setting' to 'Large Size 120 DPI'... Those were the settings. If there is need for more information please ask!...
utku selamoglu
large dpi caused the problem i think
can u try to set 120 DPI and see if u get an error again?
utkuselamoglu
calvin wrote:can u try to set 120 DPI and see if u get an error again?
Calvin, I changed my dpi setting from 96 to 120 again the same thing occured. After that changed my settings to 96 dpi again the problem gone.
utku selamoglu
I have seen other software that had also problems with the dpi size. Please never change it!
HiProfile
Post by HiProfile »
What about in the future? Laptop makers keep thinking everyone wants 2million X 1million resolution on a small lappy screen, and nobody can read text w/o dpi change, or going with a blurry lower res.
HiProfile wrote:What about in the future? Laptop makers keep thinking everyone wants 2million X 1million resolution on a small lappy screen, and nobody can read text w/o dpi change, or going with a blurry lower res.
We do want a high res with smaller DPI ;) I LOVE 15" LCD's that can get over 1600x1440 Res =)
utkuselamoglu
mine screen resolution is 1680 x 1050 pixels and the screen size is 15.4\" wide screen laptop.... Having a bit more DPI setting makes is easier to look...:)))
utku selamoglu
