Not sure if anyone else is having this problem, but no matter what settings I choose I can't seem to get the values to log properly in my AFR readings Overlay.. It only works if I stay in one cell for a long time, like if I drive normally it only catches like a cell here and there, but if I slowly climb across the map it catches alot more cells, even then Its not very many. This is making the AFR readings pretty useless and I\"m having to do it by watching the AFR meter and RPMs and kinda hit or miss adjustments.
