key on engine off, datalog shows faulty map values?
racepak
Post by racepak »
hello everyone, i'm just wonderin if what i'm experiancing is ok, when key on engine off, datalog connected map sensor shows 0mbar and occasionaly jump to 1035mbar for a split sec and returns to 0, is this a bug? bad map sensor? should i be worried? no CELs thanks
bad map sensor or wrong Baro pressure in setting. I guess bad sensor. with key on it should show outside(baro) pressure aka 1010-1024 mbar
