faded flashing CEL only when connected
Posted: Tue Jan 06, 2009 3:04 am
by 98vtec
It would only start to be seen when you are under light acceleration then go away if you hit the gas more or let off the gas. The longer i stayed under acceleration, the brighter it got and the faster it flashed. The light turned off when i unplugged the ostrich and hulog. using version R6 http://s23.photobucket.com/albums/b376/ ... D00009.flv
Posted: Tue Jan 06, 2009 7:37 am
you have some problems too sometime!... w'll figure it out like the rest
Posted: Tue Jan 06, 2009 11:01 am
by 98vtec
calvin wrote:you have some problems too sometime!... w'll figure it out like the rest
it just worried me because it changed the tune while connected. I havent actually needed to mess with my tune for the last few months until i saw something small that i needed to fix. Went in to fix it and everything changed. I got things where it needed to be and unplugged the computer. Everything went crazy lean so i think the cel was doing something in the background. Uploaded the original cal and it all went back to normal, tune wise. thanks calvin.
Posted: Tue Jan 06, 2009 7:21 pm
corrupted cal?
Posted: Tue Jan 06, 2009 7:59 pm
by 98vtec
i guess its possible. I'm running the amount of NA load columns which would be about a 3 bar map without load scalars. Just added columns so there wasn't big jumps in fueling. i'll try a prior cal and let you know.
