datalog problem
datalog problem
I can't connect to the hulog. It says can't connect to ecu. I've tried changing the serialcommdebugg to true and downloading the driver from moates. The car also starts but as soon as it starts it cuts off right away. There is also a solid cel. Thanks
debug
this is the debug test when its on auto DTL: Auto-Scan DTL: Ecu detection started DTL: baud: 38400 DTL: Cached port failed with Object reference not set to an instance of an object. DTL: Open port : 5 DTL: Open port : 5 DTL: Open port : 6 DTL: Open port : 6 DTL: Open port : 9 DTL: Open port : 9 DTL: Open port : 10 DTL: Open port : 10 DTL: The operation has timed out. DTL: Retry #:1 DTL: The operation has timed out. DTL: Retry #:2 DTL: The operation has timed out. DTL: Retry #:3 DTL: The operation has timed out. DTL: Retry #:4 DTL: The operation has timed out. DTL: Retry #:5 DTL: Port 10 is open and check ECU-ISR replied=False DTL: Port Scan Failed at port 30
this is thdebug test on manual
This is debug on manual DTL: baud: 38400 DTL: The operation has timed out. DTL: Retry #:1 DTL: The operation has timed out. DTL: Retry #:2 DTL: The operation has timed out. DTL: Retry #:3 DTL: The operation has timed out. DTL: Retry #:4 DTL: The operation has timed out. DTL: Retry #:5
doesn't get data from ecu. is the ecu running ectune? if you Key On what do u see tell me all the blinks of the MIL light
The light just comes on and stays on would you be able to remote connect to my laptop? If so what time/When My number is 443-205-2976. I need to get up and running as this is my DD. Thankscalvin wrote:doesn't get data from ecu. is the ecu running ectune? if you Key On what do u see tell me all the blinks of the MIL light
But the ostrich is connecting fine? would it be connecting if it was installed wrong? I'll check but I'm pretty sure it's in right, the red line goes toward the middle of the ecu right? I'm also sure the ecu I good it was working fine when I took it out a couple days ago with a neptune rtp.Gaskleppie wrote:ostrich mounted wrong? Solid cell is a very big reason not to get connected!The light just comes on and stays on
I checked and its in the ecu right I also tried unplugging the ostrich from the ecu and installed a chip and the car runs fine on the chip with no cel. I am also getting an error when I try to upload a base and cal. to the ostrich It keeps saying Object reference not set to an instance of an object. See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at 3™w6�p�‡‡sœ4�‡n��ly.sbbk�7�†h76m‘ež˜b‘ž.‡›�•ˆŠˆ–‹(Int32 ) at 73–��eŠbqxeŸˆ“Žˆqo’.3fx8Ÿ�Šab—3bp1gdŽ8Ž.wowyrlŠd3“�hŽhftepv.or�fˆdŠc�gžn‘yq70�‰.Invoke(Int32 ) at 73–��eŠbqxeŸˆ“Žˆqo’.3fx8Ÿ�Šab—3bp1gdŽ8Ž.�›�—‘˜‘†Ž(Object , ProgressChangedEventArgs ) at System.ComponentModel.BackgroundWorker.OnProgressChanged(ProgressChangedEventArgs e) at System.ComponentModel.BackgroundWorker.ProgressReporter(Object arg) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- eCtune Assembly Version: 0.0.2.2 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- startup_lib_net_2_0 Assembly Version: 2.0.0.0 Win32 Version: 0.0.2.2 CodeBase: file:///C:/Program%20Files/eCtune/eCtune.EXE ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll ----------------------------------------
that sounds good. if cell flashes you are now running ectune. which FTDI driver version do you have? can u install latest. make sure datalogging baud is that 38400 make sure j12 is cut
All that's already done. Version 2.2.4.0. Is the baud rate and the bits per second under usb port properties both supposed to be 38400? Thats what I've had it at. J12 is not installed at allcalvin wrote:that sounds good. if cell flashes you are now running ectune. which FTDI driver version do you have? can u install latest. make sure datalogging baud is that 38400 make sure j12 is cut
