Page 1 of 6
WEIRDNESS!!
Posted: Sat Jan 17, 2009 5:46 pm
by b20beast
I need some help. I have a Lc1 Wideband. I use the Serial input of ectune. Motor is bolt on b16a with Type R cams. Now i started a New Map to tune part throttle. Tuned is mostly to 15:1 AFR Part Throttle. Now i had a previously tuned WOT map, I switched over to the map to race somebody. Now after the race, i switched back to the part throttle map and the AFR is VERY LEAN, Like one full point leaner in some places. I Do not know where to look again. Someone Please Help me. LC1 Power goes to ECU power, and Ground to Ecu Ground.
Posted: Sat Jan 17, 2009 6:25 pm
by b20beast
AIT Sensor is not installed inside my intake tube, but inside engine bay hanging. Because i do not have a place to put it in the intake tube. AIT reads 150F ECT is 200F Now sometimees TPS at 0% reads .47V Sometimes it goes .51V For itself. Any ideas why the tps might do this?
Posted: Sun Jan 18, 2009 10:33 am
nope not TPS more like IAT sensor reading wrong values
Posted: Sun Jan 18, 2009 11:47 am
by b20beast
but why would the tps sometimes read .46V and sometimes .51V, then other times .55V
Posted: Sun Jan 18, 2009 12:56 pm
by relic1
my guess on that would be grounds (bad ground will raise and lower the voltage across two points) or sticky throttle body (doesn't allow the butterfly to close entirely every time) or bad TPS.
Posted: Sun Jan 18, 2009 1:18 pm
by b20beast
IAT goes from 110-145Degrees F
Posted: Sun Jan 18, 2009 10:21 pm
by b20beast
Ok, now i realize my tune is being messed up because tuning at diff IAT. Now the question is, How much hotter do the TEMPS run with it in the engine bay, than inside the intake tube?
Posted: Mon Jan 19, 2009 4:51 am
by Bindegal
b20beast wrote:Ok, now i realize my tune is being messed up because tuning at diff IAT. Now the question is, How much hotter do the TEMPS run with it in the engine bay, than inside the intake tube?
This is really an impossible question to answer. It would all depend on a number of factors. Like ambient temp, speed, exact placement of the sensor, placement of intake duct etc. /Allan
Posted: Mon Jan 19, 2009 9:12 am
by b20beast
I live in the caribbean so temps are like 28-36Degrees at any given day. The sensor is placed in the engine bay, just behind the transmission under the intake manifold.
Posted: Mon Jan 19, 2009 10:18 am
Just do it properly
Posted: Tue Jan 20, 2009 6:10 pm
Put it into the intake tube! Easy and your problems wil be over.
Posted: Tue Jan 20, 2009 6:53 pm
Gaskleppie wrote:Put it into the intake tube! Easy and your problems wil be over.
x2
Posted: Tue Jan 20, 2009 7:47 pm
by b20beast
today i drilled a hole and put in a grommet and in goes the iat sensor. But sometimes when i idle, i read 133 Degrees F. And the ecu still makes corrections. Anyone have any idea's or what i should check?
Posted: Wed Jan 21, 2009 3:04 am
The ecu will always correct on IAT! On a certain point you can see a correction of 0 but normally its always correcting. Thats why its so important that the sensor is in the right spot. When the engine is idling the IAT can climb up. The airspeed is very low in the intake so it has a lot of time to get heated by the radiator heat. Did you changed the IAT table?
Posted: Wed Jan 21, 2009 10:25 am
by b20beast
No i have not changed the IAT tables. The temps i am experiencing, is this normal? As much as 133 Degrees F ? I am having trouble getting my part throttle spot on. When i make changes to one area of the map, should i clear the map to see the updated changes? My afr fluctuates so much! sometimes idle at different temperatures it goes 14.7 and as lean as 16.0
