Graph datalog display
If you are recording a log and shut off the engine, you can't see anything in the gragh window display even though you can scroll in it. eCtune will resume the recording instead of starting a new one next time around and there's no way to actually end the currect recording when the engine if off beside saving the log and reloading it.
well correct when u switch off it will continue with same log. about graph i have to look into. auto sava datalog will save with timestamp if you keyon engineoff
