Innovate serial stream not working
integralactic
Post by integralactic »
I updated to r7 I try to connect datalog with Innovate serial wideband input enabled, datalog connects but O2 reading display stays at 10afr. Close ectune and opened up logworks. It connects and displays the AFR. Tried disabling then enabling, tried switching ports, rebooting laptop but it still dosent work. Is anybody else having this problem? Any ideas? It was working before I updated.
butch11a
Post by butch11a »
same here...
i was afraid of that.. i'll look at today test it. i added some code i'll release an update today
did you select innovate and the correct port in settings?
integralactic
Yes selected innovate and chose correct port, com8.
I'll test in a few hours and release an update. Sorry. But on the otherhand more wb users will have direct serial access.
please force update from start menu and test again. post asap. i just tested it
integralactic
Just tried it and it is working now. :D
ef92b
Post by ef92b »
great! i'm going to do the update later tonight. I was having the same issue just last night(30th) as what integralactic described initially.
newb a.k.a clyde(pgmfi.org)
serial is working! confirmed this morning.
ef92b
Post by ef92b »
works perfectly fine now. :D done 25 min. continuous datalogging and it's all good. thanks calvin! :)
