Page 1 of 4
Wideband Direct serial tester wanted(ZE, TE, Aem, FJO, PLX)
Posted: Fri Jan 30, 2009 11:20 am
Zeitronix -> Working!! Tech-Edge ->Working!! tested by calvin Aem Added must be tested Fjo Added must be tested Plx r-series->Working(r500, r300 should too) test by Calvin/Ervin JAW added must be tested Please post here..
Posted: Fri Jan 30, 2009 4:04 pm
by David974
If i can get my Tech Edge to work i 'll give a try tomorrow
Posted: Fri Jan 30, 2009 6:26 pm
Shoot me an email so I can send u a test version next week
Posted: Sat Jan 31, 2009 9:57 am
by Orthello
Here another TE user
Posted: Sat Jan 31, 2009 11:11 am
by DSMR
AEM here :D
Posted: Sat Jan 31, 2009 11:33 am
Can all tester mail me at calvin (at@) ectune (dot.) com
Posted: Sun Feb 01, 2009 2:47 am
by David974
email sent
Posted: Sun Feb 01, 2009 7:05 am
by 1337EJ1
I am an PLX-R500 User, if i can help you :wink:
Posted: Sun Feb 01, 2009 8:45 am
no JAW serial logging profile??? heh
Posted: Sun Feb 01, 2009 10:07 pm
JaredKaragen wrote:no JAW serial logging profile??? heh
send me the protocol it's easy to add now that i have the master classes. Send to my email
Posted: Mon Feb 02, 2009 5:39 am
I don't have it; you would have to get it from toalan from PGMFI, or http://www.14point7.com ; last time I tossed him a message/PM I got no answer back... or I would have it... Unless you wish to \"probe\" his logging software to see the protocol.. I could mail you my JAW if you;d like....
Posted: Mon Feb 02, 2009 8:38 am
by Orthello
I found this about JAW: http://www.14point7.com/Pics/JAW_Edit_D ... 1_2007.pdf see page 2 In short: Everytime you send a '0' from eCtune to JAW you'll receive a 5 byte datapackage; Ip, Ri, Engine_Hz, Vin1, Vin2 Ip = is just a 0 to 42 (inclusive) index to lookup the actual AFR value. Ri = internal resitance of Nermest cell. "16" = 750 celsius Engine_hz = RPM in Hz. (RPM/60) I'm not sure, but it looks like JAW has an AFR resolution of just 43. At least at the serial logging side. Isn't this way to less?
Posted: Mon Feb 02, 2009 8:52 am
and where is the array to lookup?
Posted: Mon Feb 02, 2009 8:55 am
by Orthello
calvin wrote:and where is the array to lookup?
That's what I was thinking too. ;) C# Source of the JAW configuration program can be found HERE. Maybe that'll help. Image
Posted: Mon Feb 02, 2009 9:17 am
Did you test TE logging with the latest version?
