MIL Shiftlight not working
2bfi
Post by 2bfi »
Under Parameters/Features/MIL ShiftLight, I have \"enable MIL shiftlight\" checked. Shiftlight rpm is set at 8296 rpm. Myy rev limiter is at 8686rpm, ignition cut. I was able to hit the rev limit without the MIL lighting up. The bulb is good coz it lights up when I turn the ignition on. Next I lowered the shiftlight rpm to 3000 rpm. The tach was already over and still no light. Is there something I'm missing?
lower it a bit more. Rpm shiftlight can be off in some situations
So your saying if you have it set at 3000rpm and your tach is showing 6000 it will not be lit up?
don't rely on the tach in the car; it can be VERY off... I have found that the MIL shiftlight can be 300-600 RPM off in different situations. try lowering it by 100RPM each step; it will probably start working.
For a rev limiter set @ 8800rpm, I usually set the shiftlight @ 8200rpm. Then, it will light up at 8600rpm. Strange but true... just accept it..
2bfi
Post by 2bfi »
ok, let me try it at a lower rpm than the desired trigger rpm. In my 2nd test above, I set the limiter at 3000. When the tach showed 3500 rpm, I let go and assumed it wasn't working.
greasemonkee
Post by greasemonkee »
All ECU's are different, the component alignment within them will vary response time. The previous one I used was quick and the rev limit cut quick, but now I have a sluggish turd.
2bfi
Post by 2bfi »
It still doesn't work. The MIL shiftlight was set to 3000 rpm. I was already at 5000 rpm and still no shiftlight. It can't be that far off can it? Does it matter that my ecu is a JDM P30? The MIL shiftlight worked with C***e and AEM EMS. So, I'm sure the ECU is capable of it and the vehicle components are good. I've included the cal file below in case that would help. TIA
2009-2-15-2 test 1.cal
(8.21 KiB) Downloaded 331 times
that sound weird. didn't use the MIL out for anything else? 2000 rpm above should work. i'll test later
2bfi
Post by 2bfi »
I didn't use the MIL for anything else. None of the GPO's are activated. I'll also test if the gear based option works.
2bfi
Post by 2bfi »
Enabling MIL Shiftlight alone doesn't work. However, enabling both MIL Shiftlight and Gear Based Shiftlight works.
i'll check again. both single rpm and gear rpm should work. if not i have to fix it
2bfi
Post by 2bfi »
Both single rpm and gear based rpm MIL Shiftlight works now.
2bfi
Post by 2bfi »
This was working in r8. Now with r9, it's back to the old problem. Plain MIL Shift light doesn't work. Gear Based MIL Shift light works.
nothing changed in the rom regarding MIL shift. it's still the same as 60 years ago:). just double check your settings. It's working in my race car.
