P30 Knock Sensor
P30 Knock Sensor
Can eCtune read/display the knock sensor voltage? I just got a cheap Del Sol VTEC, so I have a P30 I can use instead of my P05. However I saw in another thread the knock raw voltage won't be displayed in the PRO version. Can I still read & view the knock sensor's output? I recall seeing it in the graph view template before, that's what puzzles me. BTW I know its not very useful, but I know what I'm looking at regarding raw voltages. I've done a LOT of research into knock sensing itself, and was inches from buying a the knock sensor datalogger made for Megasquirt. I can't imagine the P30 working much worse, and would save me >$100. I also don't want to hook up a det can each time for minor stuff.
Well I'm hoping it will display the raw voltage, not the knock count. I wouldn't use it as front line defense, just supplement my tuning. I was thinking about getting a baseline with conservative timing, then adding timing & check for any obvious spikes. Its a motor I built myself recently, and even with the forged parts its quiet for a d16 (as far as audable noise). Worst case scenario is some time spent swapping the sensor, and me going back to the cheap ecu. I was planning on using some special shielded wire I have that's worked amazing for other things, which should help reduce any electrical noise.
