my fuel cut stopped working after the last patch, i must say its pretty frustrating, not even any of my old tunes work with fuel cut now. is there anyway to revert back to the previous version?
fuel cut still dosent work for me. force updated yesterday 6/2 didnt make any changes to my .cal put base rom and calibration went for a test drive and the car backfires and pops when I let off the throttle and decelerate. fuel cut was working before the update.
I just put a fuel cut into the fuel map. you can look at my post above for an example. I will take it out of my fuel map when I get fuel cut to work good for me through the software. It works fine for now though.
you have to do a full update(baserom+cal). Fuelcut is working.
Is the routine the same in the version available through force update and the 6.2.2009 update (demon+ostrich update). I ask these because in 6.2.2009 you ask me to test, fuel cut is working but not so good has it was in later versions (0.0.2.3.r0). I'm getitng hiccups when cruising with light throttle.
civic4g wrote:Is the routine the same in the version available through force update and the 6.2.2009 update (demon+ostrich update). I ask these because in 6.2.2009 you ask me to test, fuel cut is working but not so good has it was in later versions (0.0.2.3.r0). I'm getitng hiccups when cruising with light throttle.
r0 and r1/r2 are different. Just adjust it properly. All the values are being used correctly now.. Check the mbar and tps%. Check mbar on decel in the log file. set mbar a little higher then that... also be carefull with tps setting!
