ectune will not load
Posted: Wed Mar 11, 2009 5:22 pm
i was using it yesterday so i dont know.
eCtune's official online messageboard community.
https://ectune.hondatuningsuite.com/
https://ectune.hondatuningsuite.com/viewtopic.php?f=3&t=1804
guys i havent changed anything from the 10 hours earlier that i was using it. The laptop was in sleep mode. Pulled it out of sleep mode and tried to open it and these are the problems i am receiving.Adam Hopkins wrote:UAC is disabled right?
Reboot and it'll work fine I'd bet.Lots of times my computer screws up in sleep mode98vtec wrote:guys i havent changed anything from the 10 hours earlier that i was using it. The laptop was in sleep mode. Pulled it out of sleep mode and tried to open it and these are the problems i am receiving.Adam Hopkins wrote:UAC is disabled right?
ok i deleted everything except the settings.xml file and now i get this error: "unable to find assembly 'eCtune, version=0.02.1, culture=neutral, publickeyToekn=6ab39c117085a55.' along with the other settings errorcalvin wrote:if not one of the files are damaged. try deleting all the pref files in the settings directory and restart ectune
no i didnt. I did that exact thing and thats what happened. Regardless, i chatted with calvin over the phone and the problem is solved.RoadXY wrote:I think you got Calvin wrong: you should have deleted only the pref files in the settings directory...
