ITB> First Tune - Help ! TPS INDEXING BUG !
Posted: Sat Mar 14, 2009 7:39 am
by Chris_rai
hi i'm going with my first attemp to make all thing to work. Ectune works fine, emulator is connected, hulog too, and my LC1 wired to the com port. Engine starts, runs on idle, just playing with + and - to set the AFR at approx 13-14 ( columns 0 and 1 ), runs fine, and after 2-3 mins it will shutt off ( injector cut ? ) Fuel & ign with TPS indexing hi cam only iacv just plugged on the engine harness Help thanks
Posted: Sat Mar 14, 2009 2:22 pm
by Chris_rai
it seems to be ECT related ? the ECT rise to 65° and cut... the car wil re start and cut...
Posted: Sat Mar 14, 2009 4:23 pm
by Piv
Hi Chris, I'm french if you want any help you can contact me [email protected] and we try to sort it out, I got basemap for ITBs :wink:
Posted: Sun Mar 15, 2009 11:00 am
by Chris_rai
if TPS indexing is on, the car dies if ECT> 65° and will not restart. It will restart on MAP indexing ! so ?
Posted: Sun Mar 15, 2009 3:23 pm
by Bindegal
Which ROM version? I´m keeping an eye on this, as I have an ITB tune coming up! /Allan
Posted: Sun Mar 15, 2009 3:38 pm
by Piv
Try the 62 Rom version and disable the fuel cut as well Parameter/fuel et ignition setting/fuel cut settings Hope it helps :wink:
Posted: Mon Mar 16, 2009 11:23 am
by Chris_rai
cal
by Chris_rai
log
Posted: Mon Mar 16, 2009 11:25 am
by Chris_rai
Piv wrote:Try the 62 Rom version and disable the fuel cut as well Parameter/fuel et ignition setting/fuel cut settings Hope it helps :wink:
I can't choose the rom on the pro version ?
