calvin wrote:pls force update and test datalogging, realtime update. I just got confirmation that the closing problem is solved now realtime and datalogging.
Ok, I'll go test right now and let you know in a minute.
The emulator seems to be working now. But the data logging is still going about 1/5th the speed it used to, I tried messing with the sample rate to no avail.
why the hell is that happening what is your frame interval at the datagrid? what is the latency of the driver?
Too late for me to go test, and I have a problem with my MAP sensor but I did notice yesterday when I got it to open using .NET 3.0 and .NET 3.5 that the com port settings changed. So everyone having the issue with datalogging and the emulator check all your settings in eCtune and your com ports.
it still had a problem. I just fixed it and test in my car. I'm uploading now so force update in 10 min Zex_cool: delete license and request again
ok it works have fun im having no problems and the zeiltronix wideband serial input is also working . thanks calvin for the long hours . hope all the help helped lol
