ECTUNE Crashing every time i open it.
b3st0fth3w0rst
Post by b3st0fth3w0rst »
anyone else having this problem after updating to 2.2r9? Image
Look at the thread right underneath yours
update net framework to 3.5 sp1
HondaIsBueno
Post by HondaIsBueno »
already have .net 3.5 sp1 and still have the same problem he had.
Built Boosted D series FTW!
nce
Post by nce »
i updated to .netframework 3.5sp1 also seeing the same error that ectune has encountered a problem and needs to close. sometimes it will open and work most times it wont. when it does work datalogging doesnt show any data being recorded but it says it is connected to the ecu.
holly shit wtf is this
b3st0fth3w0rst
yes i have net framework 3.5 sp1. i tried re-installing windows and that did not help either :(
kyhatch01
Post by kyhatch01 »
iv been helping calvin with this all day hopefull it will be fixed tonight
b3st0fth3w0rst
ok, thanks for the update. I'm reinstalling net framework 3.5 sp1 right now to see if that fixes it. Are there some files i need to delete in documents and settings? i saw something about the in a few threads down from mine.
kyhatch01
Post by kyhatch01 »
iv done every thing and have not found a fix . my friends vista pc works off and on and my xp works with the debug version from calvin but not with normal version . not sure wtf the prob is but im up for another 4-5 hours to help as much as i can so hopefully he can fix it .
b3st0fth3w0rst
well re-installing framework 3.5sp1 didn't work. i guess if no fix is found i'll switch over to vista and see how that goes. I see a couple of other people have the same problem too, maybe i'll try force update again
kyhatch01
Post by kyhatch01 »
i have 2 diff installs of ectune one on xp one on vista im no programer but just wait till morning calvin should be able to fix it. need to run debug some more and find the prob
b3st0fth3w0rst
nope, didn't work either. well i hope you guys find a fix, till then i'm just going to install vista. :( (not a vista fan lol, but i need my car working)
kyhatch01
Post by kyhatch01 »
not saying vista will work id just wait till its is fixed
I have XP and eCtune starts (r9) without an default CAL and disconnected.
