Think I found a bug in the new R9?!
Hybrid96EK
Post by Hybrid96EK »
My realtime update no longer works. I am using Ostrich 2.0 and any changes I make have no real time effect. I need to manually \"Put Calibration\" to see the changes on the wideband. Tried unchecking and rechecking the realtime check box, nothing...
Maddog20
Post by Maddog20 »
Yep I just noticed that. I tried the injector kill and it did not work
Hybrid96EK
Maddog20 wrote:Yep I just noticed that. I tried the injector kill and it did not work
Good, so its not just me :)
BlindFashion
Post by BlindFashion »
Same thing here.
darkb16a1
Post by darkb16a1 »
Yep, the same here. Can anyone post his .cal and log from datalogging ? I was about to do that when I have time but I'm quite busy now.
Hybrid96EK
darkb16a1 wrote:Yep, the same here. Can anyone post his .cal and log from datalogging ? I was about to do that when I have time but I'm quite busy now.
What? I'm not sure what you want? Someone to post thier CAL file and a log from datalogging?
confUsed
Post by confUsed »
I noticed it too. Also when I used \"upload calibration\", and then tried to verify the rom, I got mismatch. I had to upload the base rom and calibration every time I did changes to make sure they were applied :?
Hybrid96EK
confUsed wrote:I noticed it too. Also when I used "upload calibration", and then tried to verify the rom, I got mismatch. I had to upload the base rom and calibration every time I did changes to make sure they were applied :?
I noticed this with previous versions.. I just figured I did something wrong. Sometimes it would work fine, other times it wouldn't verify.
fixing so realtime update is not working at all is it enabled in the emulator menu?
darkb16a1
Post by darkb16a1 »
calvin wrote:fixing so realtime update is not working at all is it enabled in the emulator menu?
Tested today. Ostrich 1, latest firmware, all worked fine with previous version release 8. Now it seems realtime update works only a few seconds at the beginning(tested with my favourite Kill Injectors function), then when you make some bigger change(for example edit 5-10 cells in fuel table) the realtime update stops working. Tried to enable/disable the realtime update checkbox, no difference. After manual upload to ostrich change is applied immediately.
i'll test it my self later...
no popup message box?
confUsed
Post by confUsed »
No. No messages or anything.
Hybrid96EK
calvin wrote:no popup message box?
I get no messages or anything. It just doesn't update/make the changes like it should.
on the bottom of the screen you can see the reaming byte updates is that counting? Can u test with the current version on force update
