Help with ID1000's ....
ls_dx
OK so, I pulled up my last used cal on my b16t... from my old injectors. Adjusted the dead time per the sheet T1 sent with my injectors. car wont idle and is dumping a shit load of fuel. What pre set inj batt offset should I be in to begin with? No wideband hooked up yet because I dont want to foul it out. Plugs are black and fouled out. its probably running at 1:1Afr lol, there is atomized fuel white smoke puffing out. what should I try next?
FACETUNED
Re: Help with ID1000's ....
Wait until you get your wideband. Your making changes and not knowing the effect.ls_dx wrote:OK so, I pulled up my last used cal on my b16t... from my old injectors. Adjusted the dead time per the sheet T1 sent with my injectors. car wont idle and is dumping a shit load of fuel. What pre set inj batt offset should I be in to begin with? No wideband hooked up yet because I dont want to foul it out. Plugs are black and fouled out. its probably running at 1:1Afr lol, there is atomized fuel white smoke puffing out. what should I try next?
I have the wideband, I just dont want to put it into the exhaust pipe until I can get this to Idle. My down pipe is soaked in gas, so are the plugs. It ran and Idled perfectly on the 660cc's that i had in there. Idles at like 16-17 afr. Now its ungodly rich. Its like a water hose of fuel spraying into my motor. Lul.FACETUNED wrote:Wait until you get your wideband. Your making changes and not knowing the effect.ls_dx wrote:OK so, I pulled up my last used cal on my b16t... from my old injectors. Adjusted the dead time per the sheet T1 sent with my injectors. car wont idle and is dumping a shit load of fuel. What pre set inj batt offset should I be in to begin with? No wideband hooked up yet because I dont want to foul it out. Plugs are black and fouled out. its probably running at 1:1Afr lol, there is atomized fuel white smoke puffing out. what should I try next?
well ectune uses msec.. maybe you have to use overall trim to bring the fuel down or bring the maps down. or multiplier?
dude, you need to enter the battery tables as they are on the card you got with the injectors, then you need to hookup your wideband, start the car up and adjust the fueltrims down until you get it back where it needs to be. If your worried about fouling out the wideband then remove a crap load of fuel trim THEN start your car and go from there.
Adam Hopkins
Seriously, Put the wideband and highlight the whole non vtec map and adjust fuel by -10% until it is close. If you fry your wideband with 10 days of 10:1 afrs I would be surprised. Your acting like you only have 5 minutes of wideband usage. HOOK IT UP.
