Well decided to play with the conditional logging again today and found a few problems. When i change the folder to save logs, it changes, but when you close the program and re-open, it goes back to TUNED MAPS. It would be nice if it stayed on the folder i choose. The second problem is that NONE of the inputs work. The only input that works is the SERVICE CHECK and it turns the MIL on all the time which is pointless. So basically none of the inputs on the list work. I have A/C input for my FTS and its works. When i tried A/C for logging it doesnt work.
service check will put the mill on. Select no input for the mil light. i'll check other inputs.
i updated the folder problem. Added a new button. Also i tested conditional switch or/and with MIL/VTP input. And it seems to be working. I'll post when a test is ready
latest force update has this fix. Please test greasemokey and report back
