I have a problem, when datalogin, the map sensor reads 5.0 volts on idle, and no change at all, and tps shows 0%, no matter if I'm pressing the gas pedal, and voltage stays with no changes at 0.47. car is smoking black, please help me asap guys,
non-vtec wrote:you might have the tps and map sensor connectors mixed up.
No Sir, not mixed up cpnnectors. This starts since ectune crashed when I was adjusting my car. And now the map I was using has 11.24 psi in all the columns, no vacuum columns at all. Wierd
try upload+baserom and ectune crash would likely not cause the tps/map not to read on KOEO
they should first read with key on engine off. map sensor should be arround 1024mbar. tps 0% and moving if you play with throttle.
