HighCam RPM scalar
Posted: Thu May 21, 2009 7:57 am
by civic4g
I have edited my HighCam RPM scalar to take advantage of not used rows (below 4000rpm). I know that at higher rpms there is no need for much resolution but want to check with you guys that it's OK and no CONS at all to do it. Right now my scalar is from 4250 to 9000 with 250rpm increase. Thanks in advance
Posted: Thu May 21, 2009 12:27 pm
theres nothing wrong with doing this.. the finer the RPM scalar the more acurate your fueling will be since the ecu isn't having to guess (interpolate) between load points.. Having more rpm break points will make your fueling more consistant and acurate. The only draw back is you have more cells to tune. ;)
