Super rich AFRs during tip in
post results when you are done. i have the rc750cc saturated injectors. injector offset FV should be similar or the same. i dont think that is the issue though....at one point i had my injector offset around 18-20FV and the issue was still there. i have the offset at 0 now and it idles/drive fine with the exception of the tip-in rich. calvin......can we get a diffrent tip-in over a certain rpm? make it adjustable under different conditions?
Weird.. What worked for me is that I kept adding injector offset until the motor is idling at around 14.5-14.9 AFR got it fully warmed up with all IAT and ECT finished their correction. I did not touch the overall fuel trim or added any fuel on my maps yet. From there I adjusted my injector battery comp table. Turned on all accessories; lights, fans, heater grid, etc.. and adjusted them correctly so AFR stayed at 14.5-14.9 with any accessories turned on during idle. Once I did that I went ahead and started street tuning and adjusted AFR accordingly. So far so good.non-vtec wrote:post results when you are done. i have the rc750cc saturated injectors. injector offset FV should be similar or the same. i dont think that is the issue though....at one point i had my injector offset around 18-20FV and the issue was still there. i have the offset at 0 now and it idles/drive fine with the exception of the tip-in rich. calvin......can we get a diffrent tip-in over a certain rpm? make it adjustable under different conditions?
